[postgis-devel] [PostGIS] #193: PGgeometry.hashCode() does not satisfy certain requirements that are standard in Java
trac at osgeo.org
Thu Jun 4 03:32:15 PDT 2009
standard in Java
Reporter: danpodeanu | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 1.3.X
Keywords: |
The org.postgis.PGgeometry class from the PostGIS JDBC extension violates
certain standard requirements of Java: for any two Java objects o1 and o2,
it should be the case that o1.equals(o2) implies
o1.hashCode()==o2.hashCode(). Thus, the following code should print 'true'
and 'true'; however, it prints 'true' and 'false' with the 1.3.6 version
of the PostGIS JDBC extension:
PGgeometry g1=new PGgeometry("SRID=4326;POINT(2.15426 41.4033)");
PGgeometry g2=new PGgeometry("SRID=4326;POINT(2.15426 41.4033)");
System.out.println(g1.equals(g2));
System.out.println(g1.hashCode()==g2.hashCode());
The error can be demonstrated with the 1.3.6 version of the PostGIS JDBC
extension (I am using the postgis_1.3.6.jar file from the official
distribution of PostGIS 1.3.6). I have also tried using an SVN version of
the 1.4.0 version of the extension and the error persists.
The effect of this error is that PGgeometry objects do not work with Java
collections as expected. For example, if g1 from the above example is
added to a Java hash-set, the set does not necessarily contain g2, and
this is counterintuive since g1 and g2 are equal. In this sense,
PGgeometry behaves differently from, say, java.lang.Integer, and this is
counterintuitive as well because both classes simply wrap a datatype.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/193>
