[postgis-devel] Re: [PostGIS] #192: Broken configuration of regression tests
trac at osgeo.org
Thu Jun 4 06:30:47 PDT 2009
Reporter: mloskot | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone:
Component: postgis | Version:
Resolution: | Keywords:
Comment (by robe):
Forgot to mention the output I get after reverting the run_test is below:
Note it seems to run twice and I get and error
/bin/sh: -c: line 0: syntax error near unexpected token `(' Between the
runs.
make -C ../postgis
make[1]: Entering directory `/projects/postgis-1.4SVN/postgis'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/projects/postgis-1.4SVN/postgis'
cp ../postgis/postgis.sql .
Creating spatial db postgis_reg TMPDIR is /tmp/pgis_reg_30651
PostgreSQL 8.2.6 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 4.2.1
(SUSE Linux) Postgis 1.4.0SVN - 2009-06-04 11:55:16 GEOS:
3.1.0-CAPI-1.5.0 PROJ: Rel. 4.6.0, 21 Dec 2007 Running tests
loader/Point.............. ok loader/PointM.. failed (sourcing shp2pgsql
output: /tmp/pgis_reg_30651/loader.err) loader/PointZ.. failed (sourcing
shp2pgsql output: /tmp/pgis_reg_30651/loader.err) loader/MultiPoint..
failed (sourcing shp2pgsql output: /tmp/pgis_reg_30651/loader.err)
loader/MultiPointM.. failed (sourcing shp2pgsql output:
/tmp/pgis_reg_30651/loader.err) loader/MultiPointZ.. failed (sourcing
shp2pgsql output: /tmp/pgis_reg_30651/loader.err) loader/Arc.. failed
(sourcing shp2pgsql output: /tmp/pgis_reg_30651/loader.err) loader/ArcM..
loader/ArcZ.. failed (sourcing shp2pgsql output:
/tmp/pgis_reg_30651/loader.err) loader/Polygon.. failed (sourcing
shp2pgsql output: /tmp/pgis_reg_30651/loader.err) loader/PolygonM..
loader/PolygonZ.. failed (sourcing shp2pgsql output:
/tmp/pgis_reg_30651/loader.err) regress. ok regress_index. ok
regress_index_nulls. ok lwgeom_regress. ok regress_lrs. ok removepoint.
ok setpoint. ok simplify. ok snaptogrid. ok affine. ok wkt. ok
measures. ok long_xact. ok ctors. ok sql-mm-serialize. ok sql-mm-
circularstring. ok sql-mm-compoundcurve. ok sql-mm-curvepoly. ok sql-
mm-general. ok sql-mm-multicurve. ok sql-mm-multisurface. ok geojson.
ok gml. ok svg. ok kml. ok regress_ogc. ok regress_bdpoly. ok
regress_proj. ok regress_ogc_cover. ok regress_ogc_prep. ok Run tests:
42 Failed: 11
/bin/sh: -c: line 0: `Creating spatial db postgis_reg TMPDIR is
/tmp/pgis_reg_30651 PostgreSQL 8.2.6 on i686-pc-linux-gnu, compiled by
GCC gcc (GCC) 4.2.1 (SUSE Linux) Postgis 1.4.0SVN - 2009-06-04 11:55:16
GEOS: 3.1.0-CAPI-1.5.0 PROJ: Rel. 4.6.0, 21 Dec 2007 Running tests
42 Failed: 11'
make: *** [check] Error 2
Ticket URL: <http://trac.osgeo.org/postgis/ticket/192#comment:4>
