[postgis-devel] Re: [PostGIS] #194: Different output from Transform function when used in a function vs. directly - redirected here from postgreSQL bug reporting
PostGIS trac at osgeo.org
Thu Jun 4 15:21:24 PDT 2009
  Reporter:  md       |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:
 Component:  postgis  |     Version:
Resolution:           |    Keywords:
Comment (by kneufeld):
 I can't duplicate this problem.  Running the above code sample, I get the
 same results:
 SELECT * FROM z_coo WHERE location = 'aaa';
        x_t        |       y_t        | location
  352043.233452746 | 5314191.37291459 | aaa
 (1 row)
 SELECT
   X(Transform(GeomFromEWKT('SRID=2285;POINT(2093904.76854
 357063.46674)'),26911)),
   Y(Transform(GeomFromEWKT('SRID=2285;POINT(2093904.76854
 357063.46674)'),26911));
         x         |        y
 (1 row)
 Mind you, I had to correct some syntax errors to make it run at all:
 ARRAY['aaa',bbb',ccc',ddd',eee'], 2285,26911); commit;
 should be:
 ARRAY['aaa','bbb','ccc','ddd','eee'], 2285,26911); commit;
 So, this is not an issue running:
                                 postgis_full_version
  POSTGIS="1.4.0SVN" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.4.9, 29 Oct 2004"
 USE_STATS
 (1 row)
 -- Kevin
Ticket URL: <http://trac.osgeo.org/postgis/ticket/194#comment:1>
