[postgis-devel] Re: [PostGIS] #185: Enhancement to ST_PointOnSurface to support CIRCULARSTRINGS and MULTICURVES
trac at osgeo.org
Sat Jun 6 11:12:12 PDT 2009
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: low | Milestone: postgis 1.4.1
Component: postgis | Version: 1.4
Resolution: | Keywords:
Comment (by robe):
I thought I had it bumped to 1.4.1? If I hadn't apologize for that. In
fact as I discovered the MM specs don't define
ST_PointOnSurface/ST_Centroid for anything but Surfaces and MULTISurfaces
(polygons, multipolygons, curvedpolygons ..).
I had someone check Oracle -- Oracle goes by the letter on this and does
not support PointOnsurface or centroid for anything but surface type
geoms.
IBM supports centroid but not point on surface for non-surfaces.
SQL Server 2008 supports point on surface but not centroid for non-
surfaces.
So I'm acutally not sure what the expected behavior should be anyway.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/185#comment:3>
