[postgis-devel] New uninstall_postgis.sql script
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Sat Jun 6 11:25:31 PDT 2009
Tom Lane wrote:
> CREATE OR REPLACE what? It seems unlikely that you need to change the
> names of the I/O functions, and you can't change the type's
> representational properties if you're hoping to do upgrade-in-place.
> So I'm not really seeing what CREATE OR REPLACE TYPE would buy exactly.
> Replacing the .so doesn't seem to be a problem, so long as you avoided
> putting any version numbers into the .so name referenced in the SQL
> function definitions.
Well we don't use the old PostgreSQL mechanism where the library
contains the major/minor numbers with a symlink; however with 1.4 the
resulting library file is named "postgis-1.4.so" or similar. The reason
for this is that 1.4 is sufficiently different under the hood for it to
be extremely useful to have different versions of PostGIS installed in
different databases within the same cluster for testing.
I think there are two cases here: the first is the 8.3 -> 8.4 migration
using the same 1.3 version of PostGIS which won't be a problem. The
second case is trying to upgrade from 8.3 with PostGIS 1.3 to 8.4 with
PostGIS 1.4 at the same time which is the one most likely to break,
especially as we have seen in the wild that due to neglect within the
upgrade script, many upgrades have not been 100% successful in the past.
But we need to treat these as two distinct cases.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
