[postgis-devel] Re: [PostGIS] #190: populate_geometry_columns gives nonstandard use of \' in a string literal
trac at osgeo.org
Sun Jun 7 21:12:51 PDT 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: postgis 1.4.1
Component: postgis | Version: 1.4
Resolution: | Keywords:
Comment (by robe):
Kevin -- sorry should have mentioned that after the fact -- yah its not
worth the change I realized for this project I'm working on -- I had
manually changed the constraints to allow a mix of MULTIPOLYGONS and
POLYGONS since it was more efficient for the front end to deal with most
as POLYGONS and there were a few MULTIPOLYGONS in there. So disregard
that.
Regarding the nonstandard use -- this is what I get on 8.4. though I may
nto be running the latest version on this box. This only shows if you
have "escape_string_warning" set to on. Which at least on windows is the
default install.
WARNING: nonstandard use of \' in a string literal
HINT: Use '' to write quotes in strings, or use the escape string syntax
(E'...').
CONTEXT: string literal in PL/PgSQL function "populate_geometry_columns"
near line 68
PL/pgSQL function "populate_geometry_columns" line 52 at assignment
(E'...').
near line 102
(E'...').
near line 146
(E'...').
near line 148
(E'...').
near line 150
(E'...').
near line 198
(E'...').
near line 200
(E'...').
near line 202
Ticket URL: <http://trac.osgeo.org/postgis/ticket/190#comment:3>
