[postgis-devel] Re: [PostGIS] #151: rt_ prefixes brake WKT Raster seemless integration
trac at osgeo.org
Thu Jun 11 14:16:45 PDT 2009
Reporter: pracine | Owner: pracine
Type: defect | Status: closed
Priority: medium | Milestone: wktraster 0.1.6
Component: wktraster | Version:
Resolution: fixed | Keywords:
Comment (by robe):
Guys I just realized a possibly small problem with using ST_ prefix.
While writing book and complaining about why relying on autocasts is bad
and you should explictly use ST_GeomFromText or CAST or what have you. It
occurred to me that the downside of using ST_ for Raster, is that you can
never declare a Text auto cast for it.
Auto casts I think are bad anyway. The point though --
In Postgis -- you can do this ST_Intersects('POINT(....)',
'LINESTRING(...)');
and PostgreSQL will happily cast both to geometry because there is an auto
cast in place.
However if you introduced an auto cast that takes WKT Raster text
representation --> RASTER -- it will break everything.
So I guess the point is if you plan to create CASTS that convert text to
RASTER -- make sure they are not declared automatic -- otherwise it would
cause an ambiguous function name error thingy.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/151#comment:11>
