[postgis-devel] [PostGIS] #197: Make check fails under PostgreSQL 8.2 OpenSUSE
trac at osgeo.org
Fri Jun 12 08:03:04 PDT 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: postgis 1.4.0
Component: postgis | Version: trunk
Keywords: |
I think this is because of our VOLATILE thingy change?
Looking at my OpenSUSE 10.3 running PostgreSQL 8.2 -- regress log starts
failing and shows this
psql:postgis.sql:2254: NOTICE: CREATE TABLE / PRIMARY KEY will create
implicit index "geometry_columns_pk" for table "geometry_columns"
CREATE TABLE
CREATE FUNCTION
psql:postgis.sql:2344: ERROR: syntax error at or near "_VOLATILE"
LINE 57: LANGUAGE 'plpgsql' _VOLATILE;
psql:postgis.sql:2443: ERROR: syntax error at or near "_VOLATILE"
LINE 87: LANGUAGE 'plpgsql' _VOLATILE;
psql:postgis.sql:2684: ERROR: syntax error at or near "_VOLATILE"
LINE 218: LANGUAGE 'plpgsql' _VOLATILE;
psql:postgis.sql:2782: ERROR: syntax error at or near "_VOLATILE"
LINE 81: LANGUAGE 'plpgsql' _VOLATILE;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/197>
