[postgis-devel] [PostGIS] #198: shp2pgsql gives bad output on bad input
trac at osgeo.org
Thu Jun 18 03:29:19 PDT 2009
Reporter: pramsey | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Mark,
Haven't had time to test this yet. Though looking at it seems like a
shame to throw away all that work. Well not throw away but not use it.
I'm still all for a switch and ideally the switch would work something
like this
value: 0 (or not specified - same behavior as 1.3.6)
value: 1 (the behavior you have currently - just break at first bad)
value: 2 (throw out bad entries) (not sure if this would be possible but
would solve most of my problems -- check but either remark out the bad
lines in the generated SQL or put an error on the screen to alert of the
bad geometry and leave it out of the generated sql).
The main issue I have is I have lets say 1,000,000 buildings to load in
and if I've got a couple of buildings with not enough points to form a
polygon -- I'm not going to waste time sitting around trying to figure out
what they meant by a 2-sided polygon. And its a pain to get rid of begin
commits. But its still good to know which records will not come thru in
which case I can fudge it and just put in a NULL for the geometry or
something.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/198#comment:5>
