[postgis-devel] [PostGIS] #202: upgrade issues
trac at osgeo.org
Thu Jun 18 08:23:26 PDT 2009
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.4.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Paul,
Sorry about that. I'm retracing my steps by reloading my database from
1.3.6 backup.
1) This is a database that has gone thru many upgrades (form 1.1) -- so
loading it from a PostgreSQL 8.2 (1.3.6) to PostgreSQL 8.4 RC1
2) Then upgrading that using the postgis_upgrade.sql (first error I got
was about my view vwtest -- so dropped that and reran script). Script
said it was fine.
3) Did select postgis_full_version() -- stated I was running
"POSTGIS="1.4.0b1" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August
2008" USE_STATS" (looks good)
3) Ran some queries -- super slow and Hmm I noticed non of my tables got
the gist index (but forgot to check if they had them before the upgrade so
this might be a restore issue or my 1.3.6 install on PostgreSQL 8.3).
4) Proceeded to build index on table -- bam
ERROR: data type geometry has no default operator class for access method
"gist"
HINT: You must specify an operator class for the index or define a
default operator class for the data type.
(Looked at my Operator Classes section and gist for geometry is missing).
I suspect this may be a false alarm that maybe there is something wrong
with my 1.3.6 install on PostgreSQL 8.4
Ticket URL: <http://trac.osgeo.org/postgis/ticket/202#comment:5>
