[postgis-devel] Specifying end cap and join styles Buffer op
strk strk at keybit.net
Sat Jun 20 14:33:00 PDT 2009
On Sat, Jun 20, 2009 at 12:00:32AM +0200, strk wrote:
> We could accept these in a single string:
> 'endcap_style=round|flat|square join_style=round|mitre|bevel mitre_limit=5.0'
Alright, I've something working with keys 'endcap', 'join' and 'limit'.
Yesterday night I've had a chat with Paul about adding 'segs' (quadrant
segments) in too thus allowing a short buffer signature like:
	ST_Buffer(geometry, float distance, 'params');
The above would be an overload of:
	ST_Buffer(geometry, float distance, int quadSegs)
My only concern is that in the (unlikely?) case someone relies on
implicit cast from text to numeric and is thus using:
	ST_Buffer(a, '10', '6'); -- '6' meaning quadSegs
will get errors on malformed params if I add the overload.
Fine for everyone to take that risk ?
--strk;
> Note though that this wouldn't really make us Oracle-compatible
> as we use third numeric argument  for  quadrant segments whereas oracle uses
> that for precision (tolerance).
> > Overload ST_Buffer().
> Ok.
> --strk;
>  Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
>  http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
