[postgis-devel] ST_OrderingEquals vs ~=
Paul Ramsey
pramsey at cleverelephant.ca
Sat Jun 20 20:30:37 PDT 2009
We have sort of a cleavage between the people who really understand
the use cases and the people who really understand the code. If there
was a suite or a write up of all the ways to exercise this stuff, I
could alter the code and do some tests. But yes, the knowledge that
it's been this way a long time sort of paralyzes me -- who knows what
a change would break.
P
On Sat, Jun 20, 2009 at 8:25 PM, Paragon Corporation <lr at pcorp.us> wrote:
> You sure it doesn't. If it doesn't then our documentation is wrong
> http://postgis.refractions.net/documentation/manual-svn/ST_Geometry_Same.htm
> l
> Also I thought it did because when I do this
> SELECT * FROM
> tbl_feature_data WHERE the_geom ~=
> '0101000020E610000009D31947329B5DC059448510E3A84240'
> I see my spatial indexes being used.
> Also when I look in the definition for gist_geometry_ops, I see it listed
> CREATE OPERATOR CLASS gist_geometry_ops DEFAULT
> FOR TYPE geometry USING gist AS
> FUNCTION 1 lwgeom_gist_consistent(internal, geometry, integer),
> FUNCTION 2 lwgeom_gist_union(bytea, internal),
> FUNCTION 3 lwgeom_gist_compress(internal),
> FUNCTION 4 lwgeom_gist_decompress(internal),
> FUNCTION 5 lwgeom_gist_penalty(internal, internal, internal),
> FUNCTION 6 lwgeom_gist_picksplit(internal, internal),
> FUNCTION 7 lwgeom_gist_same(box2d, box2d, internal)
> STORAGE box2d;
> Yah the ST_Equals things was another open question that that should use an
> index but doesn't.
> The = behavior -- I think we had big long heated arguments about this though
> can't quite remember what if anything we decided. I think it was a stand
> still and everyone was either afraid to touch it because its such a long
> standing gotcha and wasn't a big deal once you know abut it. If we change
> this, I suspect it may slow down a lot of things and I wasn't clear if the
> reason for its existence was for performance or because it ironically
> doesn't use a gist index and a non-gist based operator is needed for GROUP
> BY, UNION since in theory it shouldn't be lossy though it is really lossy.
> Do things like UNION, GROUP BY etc require btree based operators? It is
> very strange that the very thing you would think would use a gist index
> (bbox = bbox) is not defined for gist but for btree. Or at least that always
> kept me scratching my head.
> The other side effects of changing this behavior
> Pro - Leo and I have to rip out 2 pages from our book describing how to not
> be a victim of the = is not = paradox (it keeps people awake)
> Con - Leo and I will have to rip out 2 pages from our book describing how to
> not be a victim of the = is not = paradox. (it makes PostGIS more logical
> sounding)
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Kevin
> Neufeld
> Sent: Saturday, June 20, 2009 10:08 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] ST_OrderingEquals vs ~=
> Actually, looking at it, I think this is correct.
> ~= does not use indexes. The operator invokes 'ST_geometry_same' which
> exposes the C function 'LWGEOM_same' found in 'lwgeom_functions_basic.c'.
> Your other comment about ST_Equals could be looked at however.
> It currently just calls geomequals, without making use of any indexes.
> Shouldn't the function be a simply wrapper for 'SELECT $1 & $2 AND
> _ST_Equals($1, $2)'?
> Also, why is the = operator bound to lwgeom_eq and not LWGEOM_same? The
> former uses bounding boxes for comparison and the later compares exact
> geometry equality. I know that this operator is used in GROUP BY
> expressions .. but would it be beneficial to GROUP BY the exact geometries
> instead of just their bounding boxes? This is such a big PostGIS gotcha.
> Anywho, just some thoughts.
> -- Kevin
> Paragon Corporation wrote:
> > I think Kevin mentioned this before and he wasn't sure why either but
> > thought I would bring it up since I'm not clear what the reason for this
> is.
> > Our ST_OrderingEquals function is a short-hand for SELECT $1 && $2 AND
> > $1 ~= $2
> > But ~= already uses a GIST index doesn't it? So why this extra $1 &&
> > $2 check?
> > Is the && faster to compute? Or have higher selectivity?
> > Thanks,
> > Regina
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
