[postgis-devel] ST_OrderingEquals vs ~=
Kevin Neufeld
kneufeld at refractions.net
Sat Jun 20 21:41:10 PDT 2009
Paragon Corporation wrote:
> You sure it doesn't. If it doesn't then our documentation is wrong
> http://postgis.refractions.net/documentation/manual-svn/ST_Geometry_Same.htm
> l
> Also I thought it did because when I do this
> SELECT * FROM
> tbl_feature_data WHERE the_geom ~=
> '0101000020E610000009D31947329B5DC059448510E3A84240'
Hmm. Yeah, your right. I was obviously missreading the code.
The ~= operator uses the procedure ST_geometry_same
http://trac.osgeo.org/postgis/browser/trunk/postgis/postgis.sql.in.c#L972
The ST_geometry_same function simply exposes 'LWGEOM_same' (note that
it does not expose 'LWGEOM_gist_same')
http://trac.osgeo.org/postgis/browser/trunk/postgis/postgis.sql.in.c#L911
The LWGEOM_same C function is defined as a basic function, not a gist
function.
http://trac.osgeo.org/postgis/browser/trunk/postgis/lwgeom_functions_basic.c#L2669
But I see that ~= is listed as a gist operator op
http://trac.osgeo.org/postgis/browser/trunk/postgis/postgis.sql.in.c#L1042
It's curious that ~= is using gist indexing but it's exposing
LWGEOM_same - which has nothing to do with gist. ... I think.
Is it because behind the scenes the operands are automagically converted
to box2d where LWGEOM_gist_same is invoked?
Anywho, back to your original post. It does appear that
ST_OrderingEquals is invoking the index twice.
http://trac.osgeo.org/postgis/browser/trunk/postgis/sqlmm.sql.in.c#L152
But then, I can't seem to make it work at all.
kneufeld=# explain analyze select * from pts where the_geom ~=
'010100000080B75585372032413885390ABF8A2441';
QUERY
PLAN
Index Scan using pts_geom_idx on pts (cost=0.00..8.49 rows=1 width=88)
(actual time=9.469..9.657 rows=1 loops=1)
Index Cond: (the_geom ~=
'010100000080B75585372032413885390ABF8A2441'::geometry)
Total runtime: 9.968 ms
(3 rows)
st_orderingequals(the_geom,
'010100000080B75585372032413885390ABF8A2441');
QUERY
PLAN
Seq Scan on pts (cost=0.00..266343.74 rows=333300 width=88) (actual
time=0.076..9472.457 rows=1 loops=1)
Filter: st_orderingequals(the_geom,
Total runtime: 9472.499 ms
(3 rows)
-- Kevin
