[postgis-devel] Specifying end cap and join styles Buffer op
Paul Ramsey
pramsey at cleverelephant.ca
Mon Jun 22 07:51:25 PDT 2009
On Mon, Jun 22, 2009 at 5:29 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> I see, although I actually had in mind using the standard array constructor maybe something like this:
> select st_buffer(geom, 10, array['join=bevel', 'endcap=flat', 'limit=10']);
This is still an anonymous string, just one level in. I figured
array-of-array would be a good idea, until I realized that arrays are
homogeneous on type. So that this would fail:
select st_buffer(geom, 10, array[array['join','bevel'],
array['endcap','flat'], array['limit',10]]);
and this would be correct
array['endcap','flat'], array['limit','10']]);
which seems just too finicky to argue for.
I don't perceive this
as having any great claim to "internal structures" or I-am-not-a-hack
purity over this
select st_buffer(geom, 10, 'join=bevel endcap=flat limit=10');
the latter certainly uses fewer characters and is easier to type.
P. (suffering from "but, but, but, oracle does it" disease)
