[postgis-devel] [PostGIS] #38: shp2pgsql: Handling numeric field containing scientific notation
PostGIS trac at osgeo.org
Mon Jun 22 17:09:39 PDT 2009
  Reporter:  hustvedt  |       Owner:
      Type:  defect    |      Status:  new
  Priority:  medium    |   Milestone:  postgis 1.4.1
 Component:  postgis   |     Version:
Resolution:            |    Keywords:
Changes (by pramsey):
  * milestone:  => postgis 1.4.1
Old description:
> The numeric casting hack that I have in there will definitely not work in
> the dump mode of output, so maybe shp2pgsql will have to convert the
> numeric fields to an integer?
> There is what appears to be a slight issue with the .dbf part of a
> shapefile generated by ArcEditor 9.0 or 9.1 that has a value in an
> integer
> field of 10 billion or more if that shapefile is then used with
> shp2pgsql.
> Attempting to load the resulting sql file results in a casting error. One
> possible solution is to cast the field to numeric in the sql output,
> before
> pgsql attempts to store it in a int8 field.
> If a shapefile has an integer column with a value of 10 billion, some
> versions of ERSI ArcEditor will store that into the .dbf as '1.00e+010'.
> As
> far as I can tell, that is an invalid string to store in a dBase III
> file,
> since the only characters allowed in a Numeric field are {+-.0123456789}.
> shp2pgsql doesn't do any coversions on what is stored in the .dbf file,
> so
> that gets put directly into the .sql file that is generated. It does set
> the types of the fields in the sql file, of course, so that affects the
> castings that pgsql is going to do. '1.00e+010' is a valid numeric type,
> and that can be casted to an int8, with any necessary rounding done. It
> is
> not a valid int8 value, even if it will fit into an int8 field. shp2pgsql
> deduces correctly that an int8 will be needed to store the resulting
> number, but I think that is only based on the field length from the
> header
> of the .dbf file.
> One solution is that for any field that has a type of an integer, to add
> an
> explicit cast to numeric in the sql file, then psql will be able to
> handle
> this case. This is a simple solution, since it is just adding a
> '::numeric'
> after any integer field value. Patching shp2pgsql and adding a
> 'printf('::numeric);' is the easiest way to do that I can see.
> Here is what the current code will tell psql to do, and the resulting
> error:
> # select '1.00e+010'::integer;
> ERROR:  invalid input syntax for integer: '1.00e+010'
> However, if that value is cast to ::numeric first, then it will work as
> an
> int8:
> # select '1.00e+010'::numeric;
>   numeric  -------------
> 10000000000
> (1 row)
> # select '1.00e+010'::numeric::int8;
>    int8    -------------
> 10000000000
> (1 row)
> The command line we use is 'shp2pgsql -g the_geom -W UTF8 -s 4326 -c -N
> skip SAPEFILE TABLE > SQL'
> Running this sql code that shp2pgsql created generates the error,
> 'PGError:
> ERROR:  invalid input syntax for integer: '1.00e+010' ':
> CREATE TABLE 'data_staging'.'shp_121336819166268_20867' (gid serial
> PRIMARY
> KEY,
> 'flag' int2,
> 'v1' varchar(2),
> 'v2' varchar(1),
> 'v3' varchar(3),
> 'v4' varchar(3),
> 'v5' varchar(2),
> 'v6' varchar(5),
> 'v6a' varchar(16),  'v7' varchar(50),
> 'v7a' int4,
> 'v8' varchar(45),
> 'v9' varchar(5),
> 'v10' varchar(6),
> 'v11' int8,
> 'v12' varchar(32),
> 'v13' varchar(2),
> 'v17' varchar(50),
> 'v18' varchar(50),
> 'address' varchar(45),
> 'city' varchar(32),
> 'state' varchar(2),
> 'zipcode' varchar(5),
> 'zip_p4' varchar(4),
> 'v25' varchar(9),
> 'zip_p4_a' varchar(10),
> 'v33' varchar(10),
> 'v34' int2,
> 'v38' int2,
> 'v39' int2,
> 'v40' int2,
> 'v41' int2,
> 'v42' int2,
> 'v43' int2,
> 'v44' int2,
> 'v45' int2,
> 'v46' int2,
> 'v47' int2,
> 'v52' int2,
> 'v53' int2,
> 'v54' int2,
> 'v55' int2,
> 'v56' int2,
> 'v57' int2,
> 'v58' int2,
> 'v59' int2,
> 'v60' int2,
> 'v61' int2,
> 'v62' int2,
> 'v62f' int2,
> 'v63' int2,
> 'v63f' int2,
> 'v64' int2,
> 'v64f' int2,
> 'v65' int4,
> 'v65f' int2,
> 'v66' int4,
> 'v66f' int2,
> 'v67' int4,
> 'v67f' int2,
> 'v68' int4,
> 'v68f' int2,
> 'v69' int4,
> 'v69f' int2,
> 'v70' int4,
> 'v70f' int2,
> 'v71' int4,
> 'v71f' int2,
> 'v72' int4,
> 'v72f' int2,
> 'v73' int4,
> 'v73f' int2,
> 'v74' int4,
> 'v74f' int2,
> 'v75' int4,
> 'v75f' int2,
> 'v76' int4,
> 'v76f' int2,
> 'v77' int4,
> 'v77f' int2,
> 'v78' int4,
> 'v78f' int2,
> 'v79' int4,
> 'v79f' int2,
> 'v80' int4,
> 'v80f' int2,
> 'v81' int4,
> 'v81f' int2,
> 'v82' int8,
> 'v82f' int2,
> 'v83' int2,
> 'v84' int8,
> 'v84f' int2,
> 'v85' int4,
> 'cp_pct' float8,
> 'filter__' int2,
> 'sizecat' float8,
> 'joyce_st' float8,
> 'longitude' numeric,
> 'latitude' numeric,
> 'georesult' varchar(11),
> 'georstclp' varchar(2),
> 'fid_1' numeric,
> 'correction' varchar(50),
> 'long_adj' numeric,
> 'lati_adj' numeric);
> SELECT
> AddGeometryColumn('data_staging','shp_121336819166268_20867','the_geom','4326','POINT',2);
> INSERT INTO 'data_staging'.'shp_121336819166268_20867'
> ('flag','v1','v2','v3','v4','v5','v6','v6a','v7','v7a','v8','v9','v10','v11','v12','v13','v17','v18','address','city','state','zipcode','zip_p4','v25','zip_p4_a','v33','v34','v38','v39','v40','v41','v42','v43','v44','v45','v46','v47','v52','v53','v54','v55','v56','v57','v58','v59','v60','v61','v62','v62f','v63','v63f','v64','v64f','v65','v65f','v66','v66f','v67','v67f','v68','v68f','v69','v69f','v70','v70f','v71','v71f','v72','v72f','v73','v73f','v74','v74f','v75','v75f','v76','v76f','v77','v77f','v78','v78f','v79','v79f','v80','v80f','v81','v81f','v82','v82f','v83','v84','v84f','v85','cp_pct','filter__','sizecat','joyce_st','longitude','latitude','georesult','georstclp','fid_1','correction','long_adj','lati_adj',the_geom)
> VALUES ('0','IL','2','024','001','02','60100','1420240010260100','ALBION
> POLICE
> DEPT','88','ALBION','17047',NULL,'1933','EDWARDS','03',NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,'9999','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','3','0','3','0','3','999999','9','3','0','0','0','0','0','0','0','0','0','0','0','3','0','0','0','2','3','0','3','0','3','88888','8','88888','8','88888','8','88888','8','88888','8','1.00e+010','9','0','1.00e+010','9','0','0.00','1','1.00','0.00','-88.056282000','38.377029000','N','N','1856.000000',NULL,'-8.80562820000e+001','38.377029000','SRID=4326;01010000009F56D11F9A0356C061527C7C42304340');
New description:
 shapefile generated by ArcEditor 9.0 or 9.1 that has a value in an integer
 field of 10 billion or more if that shapefile is then used with shp2pgsql.
 before
 As
 far as I can tell, that is an invalid string to store in a dBase III file,
 shp2pgsql doesn't do any coversions on what is stored in the .dbf file, so
 and that can be casted to an int8, with any necessary rounding done. It is
 number, but I think that is only based on the field length from the header
 of the .dbf file.
 an
 explicit cast to numeric in the sql file, then psql will be able to handle
 '::numeric'
 error:
 However, if that value is cast to ::numeric first, then it will work as an
 int8:
 10000000000
 (1 row)
    int8    -------------
 10000000000
 (1 row)
 'PGError:
 PRIMARY
 KEY,
 'flag' int2,
 'v1' varchar(2),
 'v2' varchar(1),
 'v3' varchar(3),
 'v4' varchar(3),
 'v5' varchar(2),
 'v6' varchar(5),
 'v7a' int4,
 'v8' varchar(45),
 'v9' varchar(5),
 'v10' varchar(6),
 'v11' int8,
 'v12' varchar(32),
 'v13' varchar(2),
 'v17' varchar(50),
 'v18' varchar(50),
 'city' varchar(32),
 'state' varchar(2),
 'v25' varchar(9),
 'v33' varchar(10),
 'v34' int2,
 'v38' int2,
 'v39' int2,
 'v40' int2,
 'v41' int2,
 'v42' int2,
 'v43' int2,
 'v44' int2,
 'v45' int2,
 'v46' int2,
 'v47' int2,
 'v52' int2,
 'v53' int2,
 'v54' int2,
 'v55' int2,
 'v56' int2,
 'v57' int2,
 'v58' int2,
 'v59' int2,
 'v60' int2,
 'v61' int2,
 'v62' int2,
 'v62f' int2,
 'v63' int2,
 'v63f' int2,
 'v64' int2,
 'v64f' int2,
 'v65' int4,
 'v65f' int2,
 'v66' int4,
 'v66f' int2,
 'v67' int4,
 'v67f' int2,
 'v68' int4,
 'v68f' int2,
 'v69' int4,
 'v69f' int2,
 'v70' int4,
 'v70f' int2,
 'v71' int4,
 'v71f' int2,
 'v72' int4,
 'v72f' int2,
 'v73' int4,
 'v73f' int2,
 'v74' int4,
 'v74f' int2,
 'v75' int4,
 'v75f' int2,
 'v76' int4,
 'v76f' int2,
 'v77' int4,
 'v77f' int2,
 'v78' int4,
 'v78f' int2,
 'v79' int4,
 'v79f' int2,
 'v80' int4,
 'v80f' int2,
 'v81' int4,
 'v81f' int2,
 'v82' int8,
 'v82f' int2,
 'v83' int2,
 'v84' int8,
 'v84f' int2,
 'v85' int4,
 'cp_pct' float8,
 'filter__' int2,
 'sizecat' float8,
 'joyce_st' float8,
 'latitude' numeric,
 'fid_1' numeric,
 'long_adj' numeric,
 SELECT
 POLICE
Ticket URL: <http://trac.osgeo.org/postgis/ticket/38#comment:1>
