[postgis-devel] [PostGIS] #205: Non-standard use of literal
trac at osgeo.org
Tue Jun 23 06:15:21 PDT 2009
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone:
Component: wktraster | Version: trunk
Keywords: |
This is when deploying against 8.4RC1. 8.4 changed so they flag non-
standard use in RAISE notices.
So I get this notice
NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index
"raster_columns_pk" for table "raster_columns"
WARNING: nonstandard use of \' in a string literal
I think its in your DropRasterColumn
this line
RAISE EXCEPTION 'column \'%\' not found in raster_columns table',
column_name;
probably just need to change to
RAISE EXCEPTION 'column ''%'' not found in raster_columns table',
column_name;
See #190
Ticket URL: <http://trac.osgeo.org/postgis/ticket/205>
