[postgis-devel] [PostGIS] #210: segmentation faults in lwgeom_geos.c:pgis_union_geometry_array
trac at osgeo.org
Wed Jun 24 10:12:26 PDT 2009
Reporter: dfuhriman | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.3.7
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by dfuhriman):
Replying to [comment:2 robe]:
> I think this is the same as this bug #179
> Sadly I haven't had any success replicating the behavior consistently.
Its a long standing issue.
Hopefully the attached data will help, though like I said, this particular
case seems to be fine when using 1.3.6, it was only the update to 1.4.0SVN
that caused the problem (possibly because of the new union available in
GEOS 3.1?)
> Which version of PostgreSQL are you running by the way?
8.3.7 on a CentOS 5 box, x86_64 architecture.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/210#comment:3>
