[postgis-devel] [PostGIS] #210: segmentation faults in lwgeom_geos.c:pgis_union_geometry_array
trac at osgeo.org
Thu Jun 25 04:31:03 PDT 2009
Reporter: dfuhriman | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.3.7
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
I'm somewhat convinced that this and #179 if not manifestations of the
same disease are in the same family.
Just to test -- can everyone try the following two examples. Very watered
down. Of course don't do this on a production system unless you don't mind
it going down.
SELECT ST_Union(ARRAY[NULL,NULL,NULL,NULL]) ;
SELECT ST_MakeLine(ARRAY[NULL,NULL,NULL,NULL]) ;
In the above cases on my 8.4RC1 windows 32-bit install running PostGIS
1.4b1, GEOS 3.1.1
I get these messages:
Union says:
ERROR: Unknown geometry type: 0
Make Line says:
ERROR: Unknown geometry type: 0 and promptly kills my backend
Note that they both give the same errors and MakeLine does not use GEOS at
all. Though the makeline seems to be a more consistent killing machine
when it kills but not consistently on all installs.
I ran the same a couple of times on my
PostgreSQL 8.3.7 windows 32-bit, PostGIS 1.4b1, GEOS 3.1.1
Union says:
Make Line says:
Returns NULL as expected and gives no error.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/210#comment:9>
