[postgis-devel] [PostGIS] #200: Resolution reduction built-in to gdal2wktraster script
trac at osgeo.org
Fri Jun 26 02:56:12 PDT 2009
Reporter: mloskot | Owner: mloskot
Type: task | Status: assigned
Priority: high | Milestone:
Component: wktraster | Version: trunk
Resolution: | Keywords: overview,pyramid,resolution,reduction
Comment (by mloskot):
First set of changes (r4219). Note, georeferencing per tile is likely
broken as well as it's not very bulletproof yet. Second, if level > 1, the
script '''must''' generate table with base raster but not only downsampled
version (overview). Work in progress. Yes, progress, this is the right
term ;-)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/200#comment:2>
