[postgis-devel] Issue 122 in postgis: ST_SnapToGrid gives 13 when fed circular string
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 3 07:16:44 PST 2009
Status: Accepted
Owner: robe.... at cityofboston.gov
Labels: Type-Defect Priority-Low Milestone-1.3.X
New issue 122 by robe.... at cityofboston.gov: ST_SnapToGrid gives 13 when fed
circular string
http://code.google.com/p/postgis/issues/detail?id=122
What steps will reproduce the problem?
1. 	SELECT ST_SnapToGrid(foo1.the_geom, 0.5, 0.5)
			FROM ((SELECT ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326),
j))  As the_geom
		FROM generate_series(-10,50,10) As i
			CROSS JOIN generate_series(40,70, 20) As j)) As foo1;
What is the expected output?
IT either works or says it doesn't work with curved polygons
What do you see instead?
ERROR:  lwgeom_grid: Unknown geometry type: 13
Happens in both 1.3 and 1.4SVN
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
