[postgis-devel] configure error while building WKTRaster on Ubuntu 8.10
Tyler Erickson
tyler.erickson at mtu.edu
Tue Mar 3 07:24:51 PST 2009
I'm running into some problems building WKTRaster on my local machine
(running Ubuntu 8.10). The first issue was that the configure step
failed when it could not find ./ltmain.sh. Manually adding a ltmain.sh
file (provided by strk) allowed me to get past the configure step, but I
then encounter errors during make. Because I don't know whether the
errors are related to the custom ltmain.sh or something else, I'd like
to determine how to run the configure step without needing to manually
add the ltmain.sh file.
So my specific question is:
(1) Why would my build look for ltmain.sh (since strk indicated that the
build script doesn't use libtool) ?
The prior email thread on this issue is included below.
- Tyler
Sandro Santilli wrote:
> [moved to postgis-devel, so others can help too]
> Tyler, try copying the attached ltmain.sh.
> The build script doesn't use libtool so I'm not sure
> why it is needed. Anyway, see if the attached one fixes
> your issue.
> --strk;
>>> On Sun, Mar 01, 2009 at 06:35:42PM -0500, Tyler Erickson wrote:
>>>> Sandro,
>>>> I tried building the wktraster code from the svn, but I have run into
>>>> some problems at the configure step. Configure reports a few warnings
>>>> (missing Docbook stylesheets, missing CUnit) and then fails when it
>>>> cannot find ./ltmain.sh .
>>>> Any thoughts on how to get past this? I'm building on Ubuntu 8.10.
>>> Try running ./autogen.sh before ./configure.
>>> --strk;
>> ./autogen.sh does not create ./ltmain.sh on my system.
>> Below are the results of the svn checkout, ./authgen.sh, and ./configure
>> commands.
Tyler A. Erickson, Ph.D.
Research Scientist, Michigan Tech Research Institute, and
Adjunct Assistant Professor, Dept. of Civil & Environmental Engineering
Michigan Technological University
3600 Green Court, Suite 100
Ann Arbor, MI 48105
W 83.6889°, N 42.3021° (WGS84)
(734) 913-6846
http://people.mtri.org/tyler+erickson
http://www.mtri.org
http://www.michiganview.org
