[postgis-devel]WKTRaster:WhyhavingtocompilePostgreSQL&PostGISfirst?
Obe, Regina
robe.dnd at cityofboston.gov
Wed Mar 4 09:25:14 PST 2009
Mateusz,
> There shouldn't be any need to (re)build PostgreSQL if you use Visual
C++.
> Support (or lack of it) of easy configuration of PostGIS for Visual
C++ is a different story.
I'm curious about your statement above and would be really interested
in knowing how you tackle this. When I compile PostGIS under Linux, I do
not need to compile PostgreSQL because the developer headers and so
forth are included in the distros. Under windows I need to because as
far as I can tell the developer headers needed for PostGIS are not
there. Are you saying this step is not necessary under Windows either?
I thought there was a time when PostgreSQL was not compiled under Visual
C++ that this step was not necessary and after it went to a Visual C++
model, then this step became necessary.
> I won't repeat myself, but MinGW should be banned as it's more a
troublemaker than helps.
Again how do you compile PostGIS under anything but MingW or Cygwin, I
didn't think it was possible under Visual C++ and that was part of our
roadmap?
>> I promess I will write a compilation procedure if I can convince
>> PostGIS people to migrate the PostGIS wiki from a 90's wiki to a new
millenium
>> wiki.
> I'm far from starting a holy war, but actually, I've found the Wiki on
cef-cfr.ca far from
> being friendly.
> Just compare to MediaWiki or Trac and you will know what I mean.
In defense of Pierre here. I don't think its MediaWiki he is
complaining about but that we are running an old version and one that
doesn't easily support allowing power users to write pure html. I have
similar frustrations. But even in this mini holy war, I think
discussion is good.
All good things in life are worth criticizing. All good things in life
can be improved on.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
