[postgis-devel]WKTRaster:WhyhavingtocompilePostgreSQL&PostGISfirst?
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Wed Mar 4 13:57:15 PST 2009
Mateusz Loskot wrote:
>> Unfortunately there is with PostGIS if you use newer versions of
>> PostgreSQL. Since PostgreSQL 8.3 is now compiled with MSVC, there is no
>> way to generate the required PGXS Makefiles, and so you must use MingW
>> to generate them.
> So, how it's possible developers build extensions using Visual C++?
> One of example at the bottom of this page:
> http://www.postgresql.org/docs/8.3/interactive/xfunc-c.html
As long as you stick with standard C rather than C++ then you can
mix/match libraries between MingW/MSVC as you wish. The issue with
respect to MSVC is that PGXS (the PostgreSQL extension building
infrastructure) works using GNU Makefiles, which of course won't work
with MSVC.
I've CC'd Magnus onto this email, but as far as I know the MSVC
PostgreSQL builds don't generate the PGXS Makefiles anymore - at least,
I don't see them installed as part of the development packages.
> It may seem harsh, but in *my* opinion MinGW makes more troubles than helps.
> Considering that
> a) C/C++ code is portable
The basic C standard is portable but the libraries aren't; for example
the original Microsoft POSIX implementation was fairly broken which is
why people write their own implementations as wrappers on native Win32
calls.
> b) it can be compiled using Visual C++ and
> c) there is building configuration for Visual Studio toolset,
> then I can't see any reason why some makefiles couldn't be generated
> under Windows without MinGW or cygwin.
Well as part of the rebuilding of the PostGIS build system, I made a
conscious effort to write it in a way that would make compilation under
MSVC possible. As a result, all of the logic has been moved from the
Makefiles into autotools which generates postgis_config.h. So if you can
come up with a suitable file for MSVC, you should just be left with
standard MSVC compatibility issues.
Several people have expressed interest in helping add MSVC support, but
no-one has yet stepped up to both i) do the work and ii) continue
maintenance of the MSVC port. Until this happens then I doubt that we
will switch.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
