[postgis-devel] WKT Raster: Bug tracking
Mateusz Loskot Mateusz.Loskot at cadcorp.com
Fri Mar 6 09:02:52 PST 2009
Obe, Regina wrote:
> > Perhaps there is one, personally I've found it very helpful to be
> > able to link
> > from bug reports directly to source code revision/file/line easily,
> > as it is possible in Trac (i.e. see http://trac.osgeo.org/geos/).
> > Google Code lacks of such feature, so it requires more writing &
> > time to deal with bugs.
> Good point.  At anyrate I would like to see both projects tracked
> together  so if we eventually move back to trac for tracking, then both
> should be moved at the same time.
> Or I suppose since WKTRaster is smaller at this point, it could start
> off in trac and then we merge the core PostGIS into that trac.
Good point.
Best regards,
Mateusz Loskot
Senior Programmer, Cadcorp
http://www.cadcorp.com
For the sake of simplicity, perhaps Frank's preference will make life easier.
