[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DB backend with large geometries.
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 9 06:58:28 PDT 2009
Updates:
	Status: Fixed
	Labels: -Milestone-1.3.X Milestone-1.4
Comment #3 on issue 119 by olivier.courtin: ST_AsSVG crashed DB backend
http://code.google.com/p/postgis/issues/detail?id=119
Fix as r3813 on 1.4 branche
It will probably be not fix on 1.3 one as it implied a complete rewrite of
export
function for clean memory geometry collection handle
Join to this comment a regression test used to check that output is still
the same
before and after this commit
	svg_units  3.9 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
