[postgis-devel] Issue 91 in postgis: "makefile check" Shows check failed of sql-mm-circularstring in PostGIS
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 9 08:55:55 PDT 2009
Updates:
	Status: WontFix
Comment #2 on issue 91 by mark.cav... at siriusit.co.uk: "makefile check"
http://code.google.com/p/postgis/issues/detail?id=91
Mateusz had a similar error, and it was caused by running the regression
tests with
the PostgreSQL log level set to DEBUG. This causes extra information to
appear on
stdout which breaks the regression test harness.
I'm going to mark this as "not a bug" and close accordingly.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
