[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DB backend with large geometries.
Courtin Olivier
olivier.courtin at gmail.com
Mon Mar 9 12:19:38 PDT 2009
On Mar 9, 2009, at 2:59 PM, codesite-noreply at google.com wrote:
Regina,
> I assume this change broke my torture test. Can you try this on
> your machine to rule
> out an error in my compilation. I testd this on the latest 1.4 SVN
> and don't recall
> it ever crashing before. The below now crashes my server. I flipped
> the change back
> from fixed to testing.
I also meet crashes on gardentest with St_Dump fonction, like:
SELECT ST_Dump(foo1.the_geom)
FROM ((SELECT ST_SetSRID(ST_Point(i,j),4326) As the_geom
FROM generate_series(-10,50,15) As i
CROSS JOIN generate_series(40,70, 15) j)) As foo1;
> SELECT ST_AsSVG(foo1.the_geom)
> FROM ((SELECT
> ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j)
> As the_geom
> FROM generate_series(-10,50,10) As i
> CROSS JOIN generate_series(40,70, 20) As j))
> As foo1 CROSS
> JOIN ((SELECT ST_SetSRID(ST_Point(i,j),4326) As the_geom
> foo2
> LIMIT 3;
This one just pass on my machine,
HTH,
Olivier
