[postgis-devel] Issue 125 in postgis: postgres.h header isnot included first
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 9 16:16:43 PDT 2009
Comment #1 on issue 125 by mloskot: postgres.h header isnot included first
http://code.google.com/p/postgis/issues/detail?id=125
I'm sorry, but apparently I've had no idea that Google Code magically
reacts on some
keystrokes, so I accidentally submitted incomplete report.
The problem is that PostGIS sources does NOT include postgres.h header
first, on top
of other source files, as chapter 34.9.2. "Base Types in C-Language
Function" of
PostgreSQL manual specifies:
  Note that you should always include postgres.h first in any source file,
  because it declares a number of things that you will need anyway.
This causes number of problems while building PostGIS using Microsoft
Visual C++
(8.0) compiler.
I attached patch I generated against recent svn trunk revision and tested
on Linux.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
