[postgis-devel] Issue 87 in postgis: Probe_Geometry_Columns does not parse an SRID of -1
codesite-noreply at google.com
Mon Mar 9 23:54:18 PDT 2009
Updates:
Status: Testing
Comment #3 on issue 87 by ke... at refractions.net: Probe_Geometry_Columns
http://code.google.com/p/postgis/issues/detail?id=87
I committed a small patch that seems to fix this in the 1.3 branch.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
