[postgis-devel] Issue 124 in postgis: Missing CompoundCurve parser test when disjoint segments
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 10 07:22:03 PDT 2009
Updates:
	Status: Fixed
Comment #2 on issue 124 by olivier.courtin: Missing CompoundCurve parser
http://code.google.com/p/postgis/issues/detail?id=124
Successfuly tested with following tests cases:
SELECT asewkt(geomfromewkt('COMPOUNDCURVE(CIRCULARSTRING(0 0, 1 1, 1 0), (1
0, 30
6),CIRCULARSTRING(30 6, 34 56, 67 89))'));
-> OK
0, 30
6),CIRCULARSTRING(30 5, 34 56, 67 89))'));
-> KO
1, 30
-> KO
Backporting to 1.3 seems not a priority
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
