[postgis-devel] Issue 105 in postgis: pgsql2shp seems to produce incorrect dbase files, problems importing into Gnumeric
codesite-noreply at google.com
Tue Mar 10 07:34:06 PDT 2009
Updates:
Status: Fixed
Comment #3 on issue 105 by pwramsey3: pgsql2shp seems to produce incorrect
http://code.google.com/p/postgis/issues/detail?id=105
(No comment was entered for this change.)
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
