[postgis-devel] Issue 89 in postgis: transform() grid-shift 2nd chance logic defective
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 10 07:58:11 PDT 2009
Comment #10 on issue 89 by mark.cav... at siriusit.co.uk: transform()
http://code.google.com/p/postgis/issues/detail?id=89
William,
I've just committed the required changes for this to SVN trunk, including
adding a
new section to the manual to reflect this:
http://postgis.refractions.net/documentation/manual-svn/ST_Transform.html
Since this is quite a major change in the way re-projection works, it's not
really
possible to backpatch to 1.3. However, if you wish to test then please
download
latest SVN trunk or if you wait a few days we hope to have a usable 1.4
beta available.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
