[postgis-devel] Issue 89 in postgis: transform() grid-shift 2nd chance logic defective
codesite-noreply at google.com
Tue Mar 10 08:14:16 PDT 2009
Comment #12 on issue 89 by william.... at acm.org: transform() grid-shift 2nd
http://code.google.com/p/postgis/issues/detail?id=89
Thanks a lot, Mark. I hadn't looked at recent updates of the PostGIS
documentation.
The latest version is beautiful, from both an asethetic and functional
perspective.
The last section of the updated ST_Transform page ("Configuring
transformation
behaviour") is all the detail one could ask for, even though most of the
problematic
action is at the proj.4 layer, below PostGIS itself. I'll try to give the
SVN
version a whirl this week and post results here.
-- Bill
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
