[postgis-devel] Issue 131 in postgis: Remove GEOS 2.2 support and test for GEOS >= 3.0
codesite-noreply at google.com
Tue Mar 10 12:24:11 PDT 2009
Updates:
Status: Fixed
Comment #1 on issue 131 by mark.cav... at siriusit.co.uk: Remove GEOS 2.2
http://code.google.com/p/postgis/issues/detail?id=131
Change made to SVN trunk, including tidying up of all the outstanding
compilation warnings against GEOS.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
