[postgis-devel] Re: PostGIS infrastructure
Kevin Neufeld kneufeld at refractions.net
Thu Mar 12 09:38:08 PDT 2009
It's back up again.
Yeah, Mark, I hear you.  And having more than a couple of people with root access to such an environment (esp. in
different time zones) would indeed be welcome.
I was just talking with a few folks here and we would be OK with the postgis repository moving elsewhere.  We realize
that the hosting box is incredibly old and in *desperate* need of TLC.  We are also extremely busy and find it tough to
give the box the attention it needs.
So, we're open the idea.  Come up with a strategy and specifics, and we'll try to work out the details.
Cheers,
Kevin
Mark Cave-Ayland wrote:
> Kevin Neufeld wrote:
>> Hi all, I just noticed that the svn repository is out of commission.
>> We're working to get this back online asap.  Thanx for bearing with us.
>> Cheers,
>> Kevin
> Hi Kevin,
> One of the conversations we had at the code-sprint was a discussion of
> infrastructure issues, in particular related to bug tracking/SVN/wiki
> integration.
> AIUI the issue here is that the postgis web/SVN server runs an old
> version of BSD which has the following issues:
> i) it suffers from a file handle leak which often causes outages like this
> ii) we can't run Trac or newer versions of SVN
> The lack of integration between bug tracking/SVN and the inability to
> view changesets on the web is something that developers do notice and
> struggle with on a regular basis. As I see it, the potential solutions are:
> i) bug Refractions until they upgrade the server :)
> ii) move SVN hosting to an external server (e.g.
> postgresql.org/osgeo.org) and change svn.refractions.net to point to it.
> As a potential solution, I'm leaning slightly towards ii) since there is
> potential for other non-Refractions people to have root access to the
> server, and hence someone in another timezone can restart things if they
> break (i.e. if you're on holiday we don't have to ring you up and bug
> you all the time!).
> Thoughts?
> ATB,
> Mark.
