[postgis-devel] Issue 136 in postgis: Remove deprecated definitions from postgis.sql
codesite-noreply at google.com
Mon Mar 16 07:10:58 PDT 2009
Status: New
Owner: ----
New issue 136 by mloskot: Remove deprecated definitions from postgis.sql
http://code.google.com/p/postgis/issues/detail?id=136
This is not a bug report but suggestion of improvements.
There is a lot of definitions marked as deprecated in postgis.sql file
I believe it would be good to remove all deprecated functions and
definitions from postgis.sql file in the next release.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
