[postgis-devel] about get/set wktraster sql funtion name convention
xie_jiong
xie_jiong at 163.com
Mon Mar 16 18:02:57 PDT 2009
Hi
In sql/mm, it seems only one sql funtion has get/set semantic, that is st_srid.
get version: st_srid()
set version: st_srid(srid num)
same funtion name ,and different para, we could call it as overroad mode.
now we are doing with raster, there are many get/set semantic sql funtions, we may have 3 choices:
(1) overroad mode: rt_value(raster, integer, integer, integer, float8) and rt_value(raster, integer, integer, integer)
(2) explicit set/get mode: rt_setvalue(raster, integer, integer, integer, float8) and rt_getvalue(raster, integer, integer, integer)
(3) explicit set/implict get mode: rt_setvalue(raster, integer, integer, integer, float8) and rt_value(raster, integer, integer, integer)
which form of name convention should we follow?
My view is:
(2) is clarity, but as for many long name functions, plus get/set seems verbose
(1) seems close to standard, but sql/mm only has jut one model - st_srid could follow,and semantic seems not very clear when funtion in sql statement(is it?).
(3) is OK, but lack of symmetrical beauty.
Jiong
postgis-commits mailing list
postgis-commits at postgis.refractions.net
http://lists.refractions.net/mailman/listinfo/postgis-commits
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090317/f7ac3a7b/attachment.html>
