[postgis-devel] Re: PostGIS infrastructure
Christopher Schmidt
crschmidt at metacarta.com
Mon Mar 16 18:22:51 PDT 2009
On Mon, Mar 16, 2009 at 03:51:34PM -0700, Jeff Lounsbury wrote:
> Official Refractions Response below... :-)
> We are pretty much OK with whatever the community wants in terms of PSC,
> and project infrastructure etc. There are basically only two things that
> we would not agree to do which are:
> 1) Copyright. I'm not sure what exactly going into incubation means with
> regards to copyright. One thing in particular that we would not do is
> assign copyright to someone else to allow the licenses to change etc. I
> haven't seen anything about this so I will assume that is not necessary
> to go into OSGeo incubation.
Correct.
> 2) Website. We do feel our postgis website is a valuable asset to our
> consulting marketing/advertising so we cannot agree to just shut that
> down and point everyone at a generic OSGeo site. Maybe we can incubate
> the other things first: svn, bug tracker, etc then see if anything
> changes, but for now we'd rather leave the site as is.
Website does not *have* to change to complete incubation -- so long as
the website is not directly at odds with the community desires, at least
:) (OpenLayers still self-hosts our infrastructure 1 year after
completing incubation.)
> Cheers,
> -Jeff
> Mark Cave-Ayland wrote:
> >Paul Ramsey wrote:
> >>I ran the idea past osgeo, and they'll have us, though they would
> >>prefer if we signalled an intent to enter incubation as an osgeo
> >>project at the same time. Becoming an osgeo project is basically in
> >>line with our thoughts about having some actual procedures for project
> >>management, and adds an extra task around reviewing our intellectual
> >>property and copyright situation (which would be healthy (since we
> >>have some license conflicts in our code base)).
> >>See the principles of incubation for an idea of what we'd be signing
> >>up for: http://www.osgeo.org/incubator/process/principles.html
> >>If we go that way, we can move as much or as little as we want. SVN is
> >>on the table now. To that I'd add the bug tracker. I even volunteer to
> >>figure out how to extract our data from Goog to import into trac.
> >>Having a real trac/svn instance would be awsome. Moving mailing lists
> >>is also possible if you want to do that too (and should be pretty
> >>trivial, since osgeo uses mailman too).
> >>P.
> >Okay, since we don't have an official PSC, who makes the decision as to
> >whether we should incubate with OSGeo? Should we just have an on-list
> >vote on -devel? I guess we need some kind of official response from
> >Refractions as to whether they are happy with this too - Kevin?
> >ATB,
> >Mark.
> Jeff Lounsbury, Senior Manager
> Refractions Research
> Suite 300 - 1207 Douglas St
> Victoria, BC, V8W 2E7, Canada
> ph: (250)383-3022
> fax:(250)383-2140
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Christopher Schmidt
MetaCarta
