[postgis-devel] run_test and PostgreSQL user
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Thu Mar 19 06:17:11 PDT 2009
Courtin Olivier wrote:
> Hi,
> When i play with make check (or only run_test on a single unit test), i
> must
> launch the process as a postgres system user, something like:
> $ sudo su postgres -c "./run_test a_test"
> As i configure pg_hba.conf with postgres user with trust
> authentification mode, i don't feel this so practical.
> Below a patch to add the ability to specify a PG_USER
> in run_test.
> Thoughts, reactions ?
Hi Olivier,
Specifying the default user for any libpq application can be done using
the environment variable PGUSER like this:
PGUSER=postgres ./run_test a_test
Then again, I don't recommend running PostgreSQL as the postgres user
for development purposes, since it's a pain to keep switching users.
It's far better to install everything into a single home directory and
then configure .bash_profile to set any default ports/users if required.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
