[postgis-devel] Issue 139 in postgis: Default selectivity returned when geometry used for restricted join comes from another table, but accurate when from WKT
codesite-noreply at google.com
Thu Mar 19 14:26:44 PDT 2009
Status: New
Owner: ----
New issue 139 by mose.andre: Default selectivity returned when geometry
WKT
http://code.google.com/p/postgis/issues/detail?id=139
What steps will reproduce the problem?
-- TEST CASE
CREATE TABLE points(point_id bigint, point geometry);
-- Some points in the unit square
INSERT INTO points (point_id, point) VALUES (generate_series(1, 100000),
ST_MakePoint(random(), random()));
CREATE INDEX points_point_index ON points USING gist (point);
ANALYZE points;
CREATE TABLE shapes(shape_id bigint, shape geometry);
-- A shape covering a bit of the unit square
INSERT INTO shapes (shape_id, shape) VALUES (1, GeomFromText('POLYGON((0 0,
0 .1, .1 .1, .1 0, 0 0))'));
-- Restricted join (1)
EXPLAIN ANALYZE SELECT
count(*)
FROM
points
INNER JOIN shapes ON ST_Contains(shape, point)
WHERE
shape_id=1;
-- Constant restriction (2)
count(*)
FROM
points
WHERE
ST_Contains(GeomFromText('POLYGON((0 0, 0 .1, .1 .1, .1 0, 0 0))'), point);
What is the expected output? What do you see instead?
In case (1) I expected to see an accurate estimate of the rows returned but
see 1 instead of something ~1000. For more information, please see:
http://postgis.refractions.net/pipermail/postgis-devel/2008-September/003547.html
What version of the product are you using? On what operating system?
postgis_full_version | POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel.
4.5.0, 22 Oct 2006" USE_STATS
version | PostgreSQL 8.3.3 on x86_64-redhat-linux-gnu, compiled by GCC gcc
(GCC) 3.4.6 20060404 (Red Hat 3.4.6-9)
Please provide any additional information below.
Another instance of someone running into a similar thing is in this thread.
Maybe there's a reason we shouldn't be expecting real selectivity estimate
in this case...
http://postgis.refractions.net/pipermail/postgis-users/2009-March/023043.html
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
