[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DB backend with large geometries.
codesite-noreply at google.com codesite-noreply at google.com
Fri Mar 20 09:13:05 PDT 2009
Comment #12 on issue 119 by pwramsey3: ST_AsSVG crashed DB backend with
large geometries.
http://code.google.com/p/postgis/issues/detail?id=119
Actually, this crashes for me on OS/X on the latest checkout.
POSTGIS="1.4.0SVN" GEOS="3.1.0-CAPI-1.5.0"
PROJ="Rel. 4.6.0, 21 Dec 2007" (procs from 1.4 USE_GEOS=1 USE_PROJ=1
USE_STATS=1 need upgrade)
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
