[postgis-devel] Issue 95 in postgis: PostGIS 1.4 documentation update
codesite-noreply at google.com
Fri Mar 20 09:46:42 PDT 2009
Comment #13 on issue 95 by mark.cav... at siriusit.co.uk: PostGIS 1.4
http://code.google.com/p/postgis/issues/detail?id=95
Hi Kevin.
Remember that only && has a selectivity function that will be anywhere
meaningful.
Just because an operator is indexable, doesn't mean that the planner *has*
to use it.
What happens if you do a "SET enable_seqscan = 'f'" before trying your
query?
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
