[postgis-devel] Compilation using Visual C++ 8.0
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Sat Mar 21 02:32:54 PDT 2009
Mateusz Loskot wrote:
> Mark,
> I haven't move to that yet. I'll work on this during the weekend, so
> hopefully it's ready for Monday.
Thanks Mateusz.
I've applied some header changes in the meantime which should help you
out. One of the things I noticed from your original patch were that you
set _USE_MATH_DEFINES within postgis.vsprops and also within individual
files. Can we not just keep this defined within postgis.vsprops?
Otherwise I can see this making more work to keep the MSVC build up to date.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
