[postgis-devel] Function Sigs
Paragon Corporation lr at pcorp.us
Sat Mar 21 06:59:29 PDT 2009
Mark,
I'm okay with a new section, but I don't like the term Developer-only
because it sounds snooty and also suggests you should never use these.
How about we just call this section -
Trouble Shooting Functions
(and put a note that these should be considered if you are running into
issues but are not to be used in production.  I can also document the
specific use cases where these may be useful).
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Saturday, March 21, 2009 9:16 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Function Sigs
Paragon Corporation wrote:
> Can we keep the ST_HasBBOX for now.  You have the companion
> ST_AddBBOX, ST_DropBBOX as keep so it seems almost silly to delete the
ST_HaSBBOX.
> I'm okay with deprecation, but I personally use these because of some
> bug issues in earlier  8.3 releases and they are documented in the
> current documentation as well.
> Thanks,
> Regina
I'd like to see all of these functions moved to a Developer-only/unsupported
section - users really should not be using these functions in their own
applications, but it's useful to keep them around for troubleshooting.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS Sirius
Corporation plc - control through freedom http://www.siriusit.co.uk
t: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
