[postgis-devel] Issue 142 in postgis: 1.4 snapshot build is broken
codesite-noreply at google.com codesite-noreply at google.com
Sat Mar 21 18:51:53 PDT 2009
Comment #2 on issue 142 by mloskot: 1.4 snapshot build is broken
http://code.google.com/p/postgis/issues/detail?id=142
This is not related to versions but to incomplete or broken process of
generating
build scripts.
In the snapshot, libtool script is provided (and without executable mode
set) which
actually is not needed, but ltmain.sh is necessary. So, this is ltmain.sh
missing in
the snapshot.
The snapshot (as release package) should include following helper scripts:
config.guess
config.sub
configure
depcomp
install-sh
ltmain.sh
missing
When building PostGIS SVN code, autogen.sh does not call libtoolize which
is required
to get ltmain.sh script which in turn is used to generate libtool. So,
users are
forced to call libtoolize manually and it's better to call libtoolize
--force --copy,
then all files are copied but no symlinks are used.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
