[postgis-devel] Issue 142 in postgis: 1.4 snapshot build is broken
codesite-noreply at google.com codesite-noreply at google.com
Sat Mar 21 19:49:02 PDT 2009
Comment #4 on issue 142 by mloskot: 1.4 snapshot build is broken
http://code.google.com/p/postgis/issues/detail?id=142
If I run ./configure without ltmain.sh file (see attached log and rm
ltmain.sh), it
fails. This is expected behavior because ltmain.sh generates libtool which
is crucial.
Perhaps this particular issue is related to versions, see 8.3.9.1
http://www.gnu.org/software/automake/manual/html_node/Libtool-Issues.html
In any case, libtoolize has to be called at some point, imp- or explicitly.
	postgis-config-rm-ltmain-sh.txt  7.9 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
