[postgis-devel] Issue 142 in postgis: 1.4 snapshot build is broken
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 23 15:15:52 PDT 2009
Comment #9 on issue 142 by pwramsey3: 1.4 snapshot build is broken
http://code.google.com/p/postgis/issues/detail?id=142
Close,
I tried this out, removing the autotools artefacts (config.*, install-sh)
and running your autogen.sh. First I
found that version testing really *is* needed, not just a TODO, as my
glibtoolize hated the extra parameter, so
I manually changed that for testing purposes. Second, I found that after
running autogen.sh I was still missing
install.sh
configure: error: cannot find install-sh or install.sh
in "." "./.." "./../.."
I'm not sure what auto* invocation installs install-sh, but not one in
autogen apparently.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
