[postgis-devel] Issue 142 in postgis: 1.4 snapshot build is broken
codesite-noreply at google.com
Tue Mar 24 08:19:40 PDT 2009
Comment #13 on issue 142 by mloskot: 1.4 snapshot build is broken
http://code.google.com/p/postgis/issues/detail?id=142
I'd like to report that I can build PostGIS trunk r3935 on Linux (Ubuntu
8.10,
32-bit) using GEOS from SVN trunk as well.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
