[postgis-devel] Issue 142 in postgis: 1.4 snapshot build is broken
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 24 08:48:00 PDT 2009
Comment #16 on issue 142 by mark.cav... at siriusit.co.uk: 1.4 snapshot build
is broken
http://code.google.com/p/postgis/issues/detail?id=142
Hi Kevin,
Have you tried adding the --force / -f options to libtoolize and/or
autoconf in
autogen.sh?
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
