[postgis-devel] Issue 143 in postgis: regress_ogc failed for trunk on Linux
codesite-noreply at google.com
Tue Mar 24 10:19:02 PDT 2009
Comment #1 on issue 143 by mloskot: regress_ogc failed for trunk on Linux
http://code.google.com/p/postgis/issues/detail?id=143
This is false alarm. The failing test was caused by a bug I introduced in
recently while refactoring (my bad).
The GEOS trunk has been already fixed
(http://trac.osgeo.org/geos/changeset/2304)
and now all tests pass for PostGIS trunk.
So, the ticket is to be closed.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
